I'm thinking that these are integrated graphics, which would most likely be slower than the 6200. Also, if you're considering getting that 6200. Get the 128 MB version (unless it's cheaper for the 256 one) since having 256 MB of RAM won't benefit over 128 MB.
Actually I've already got the 6200 but to my surprise it's very slow in some aspects. For example, Java/Swing applications are flicking on my screen. I tested both Linux and Windows and the performance was really unacceptable. I don't know if this a bug or not. 🙁(
SiS 651, being a chipset-integrated shared-memory effort, is about an order of magnitude slower in most things than a 6200, even if the latter is a castrated "TurboCache" version.
