- Jan 7, 2002
- 12,755
- 3
- 0
SiPix Pocket Printer for Notebooks and PDAs
Take it with you anywhere. Use it as a doorstop.
You can even level out those uneven tables!
$7.99 + $5 Shipping and Handling
The Pocket Printer A6 is a compact and lightweight mobile printer, perfect for the on-the-go business professional. The SiPix A6 Pocket Palm Printer connects easily to either PCs or Palm Pilots. Now don't be expecting this to be as fast as your in-office printer or to print in color with laser quality. But it works pretty dang good for printing text documents and spreadsheets while on the go - it churns out documents at 2 ppm with a decent 400 dpi resolution. The Sipix weighs in at less than 1 pound and truly is palm sized at 5.8x4.25x.9 (ok - woot has bigger hands than you)
Because it uses a direct thermal printing method, you'll never have to replace ribbons or ink cartridges. All you need is paper and batteries - if you use the AC adapter your only expense will be replacement paper rolls. The Sipix also uses your notebook or PDA's infrared interface so you don't have to worry about messing with cables.
# ** Palm Requirements ** Palm powered devices using Palm OS 3.1-4.0
# Infrared capable
# Hot-sync to PC
** Pocket PC Requirements **
# Pocket PC devices running Windows CE 2.0-3.1 (devices using StrongArm, Hitachi SH3 or MIPS processors)
# IrDA capable
# ActiveSync to PC
** PC Requirements **
# Pentium processor or higher
# Microsoft Windows 98/98SE/ME/2000/XP
# IrDA capable or Serial Port
Specifications:
# Condition: New, retail box
# Printing Method: Direct thermal
# Print color: Monochrome
# Print Resolution: 400 dpi
# Active Image Width: 3 3/4"
# Media Width: 4 1/8"
# Media Length: Sheet - 5 3/4", Roll - 8'2"
# Media Thickness: 60-90um
# Interface: IrDA 1.0, Serial RS-232
# Print Speed: 2ppm
# Power Source: 4 AA (included) AC Adapter 9V, 1.5A (included)
Retail Package Includes:
# Pocket Printer A6 with built-in infrared
# Serial Printer Cable
# Owner's Manual
# AC Power Adapter
# One (1) Roll A6 Printer Paper
# Printer Travel Bag
# 4 AA Batteries
# Driver CD containing:
# Windows 98, 98SE, 2000, ME printer drivers
# XP drivers dowloadable at www.sipixdigital.com/support
# Pocket Printer application software
Text
# Infrared capable
# Hot-sync to PC
# IrDA capable
# ActiveSync to PC
Specifications:
# Print Speed: 2ppm
# Owner's Manual
# AC Power Adapter
# 4 AA Batteries
Text
