- Jul 12, 2011
- 12
- 0
- 0
Hi everyone,
I'm reading these reviews for graphic cards and they talk a lot about 2560x1600 resolutions so I was wondering if anyone can help me find a good single slot card upgrade. Due to motherboard (Asus P5K-E) and space constraints, I'm looking to upgrade my graphics card for 22" (1920x1080 resolution) monitor.
My current computer contains:
I don't plan on getting a new computer for another year or two, but I am hoping to be able to use move the video card over when the time comes. But because of space constraints, 22" is probably the max I can go. The games I have installed right now are: WoW, Rift, Civilization 5, Shogun 2. I can't play first person shooters, so I guess my requirements may not be as stringent. But I do want to play Diablo 3 when it comes out.
My budget is below $200, but if something's really good at $250 i might change my mind. I'm currently looking at nVidia 460 (possibly 560) and Radeon 6870/6950 ... Would you think that these are overkill for my configuration?
Also, are there any brands I should keep in mind when looking for cards? I'm okay at finding chipsets but I don't know the difference between brands.
Thank you everyone for your help in advance!
- Asus P5K-E motherboard (I have two PCIe slots, but one at 16x and one at 4x). I believe it is crossfire compatible, but not optimal. I'm okay with single slot.
- Intel Core 2 Duo E6750
- 8gb RAM (DDR2 PC2-6400) w/ Win7 64-bit
- BFG nVidia GeForce 8600GTS
