- Nov 13, 2006
- 7
- 0
- 0
Hi guys,
Almost a year ago I posted a topic about whether I could include a gpu block in my loop. I got some very helpful replies from the members of this forum (aigomorla particularly) and decided that it wasn't quite worth the effort.
A year later, and I felt that I could not ignore the attraction of two 4850s in Crossfire. So I just installed those and...well, they're ridiculously hot.
My airflow within my case is alright, I think, but under full load my cards soar to just over 100degC. I didn't dare try to see how high those temps went if I continued loading the cards. They don't really drop in temperature that much even if I leave the side of my casing open and they idle at 80deg at default fan speeds. I can bring the temps down to about 60 deg with the fans operating at 55% of max. BTW, my ambient is about 26degC
Yes, following the fan problems that people are having with 4850s, I've changed the cooling profile for the cards so the fans operate quite fast, but I'm beginning to think that the stock cooling solution just can't deal with the sheer heat generated by these cards.
So I'm thinking of water cooling them and I would be very very grateful for all your views on this.
I'm currently running the following WC setup:
NexXos II rad which looks something like this:
http://www.alphacool.com/shop/...me-II-Rev-2--4639.html
NexXos Highflow CPU block:
http://www.alphacool.com/shop/...-Socket-775--4986.html
and an Eheim 600 pump (600l/h with a lifting height of 1.3m)
Tubing is 10/8mm (OD/ID)
My rad is mounted externally with 2 fans.
Oh, and I have an E4300 which has been o/c'd to 3.2ghz (idles at 26 to 27degC).
I bought all the above as a kit last year, which explains why it isn't the best, but it's worked for me so far, as I'm only using it to cool the CPU. I realise that I could have probably done better by buying better parts myself, but I had to start somewhere.
Anyway, I'd like to be able to run everything on a single loop, so I was considering the following:
1. Changing the rad to a Thermochill PA120.3
2. Getting 2 x Swiftech MCW60 for the gpus.
The proposed loop is rad -> res -> pump -> cpu -> gpu1 -> gpu2
Please note that my considerations are not to overclock the gpus, but to just get the overall heat of those gpus down to somewhere far below there 100degC temps.
Is my plan possible, or are the three processors far too hot to cool in a single loop like this, even for a PA120.3? Is my pump too weak?
What if I want to switch to a Q9xxx or Q8xxx cpu in the future? Can the proposed loop take the heat?
Thanks in advance guys. I would really appreciate the help.
