Carson Dyle
This is an intermittent problem we've had for the past several years.
I live in a duplex with one water service/meter feeding both residences. Also, one sprinkler system that services both yards. In both residences when we open a faucet, sometimes we'll hear a very loud humming/squealing vibration sound coming from the pipes. It's pretty nasty. Sounds like something will blow if it isn't stopped within a couple of seconds. Usually we can simply close the faucet and open it back up again immediately and the noise is gone. Lately, though, it's gotten worse, to where it sometimes takes two, three, even four open/close cycles. After it happens, it then doesn't happen again for a time period ... maybe an hour or two between incidences.
As best as I can remember, this only happens in the winter, when the sprinkler system is turned off. That usually happens in October, and the system is blown out with air. It gets turned on again in late May.
It only happens when we open kitchen or bathroom faucets, either hot or cold water or both. I don't think it's ever happened when flushing a toilet or opening the tub/shower faucet.
We had an issue with very high water pressure here about ten years ago that burst a pipe, so had a pressure relief valve installed. I haven't had the pressure tested in recent years, but wouldn't be surprised if it's crept up again. We have great water pressure.
Any ideas what's going on, and where the problem may be? I suspect it's caused by air in the pipes, although I don't understand how it would be cleared just by closing/opening the faucet again. Could it possibly have something to do with the sprinkler system, like maybe a bad backflow prevention valve?
