Sims problem
jema
296
I have a snack bag that is stuck to the floor and unselectable, any ideas on how to remove it?
RSMemphis
1,521
From Gamespot Hints:
While playing a game, press [Ctrl] + [Shift] + [Alt] + C to display a prompt
box in the upper left corner of the screen. Then, enter one of the following
codes to activate the corresponding cheat function. Note: Enter [Exclamation
point] at the prompt to repeat the last cheat entered. Enter a [Semi-colon]
between codes to enter multiple codes at the same time.
move_objects - Move any object
If that does not work, I don't know either.
RSMemphis
1,521
Odd.
Just to make sure: You only entered "move_objects", right?
not the stuff after the hyphen as well.
jema
296
And dont I feel like a pure bread idiot!
I've been missing that last "s" the whole time...
Sorry...
