CrazyCoolDealz
Text
Access files faster than ever with the SimpleTech Bonzai Xpress USB 2.0 Flash Drive.
Bonzai achieves a fast data-transfer rate of 60MB/s (480 Mb/s) by using the latest USB technology, the Hi-Speed USB 2.0, which is backward compatible with USB 1.0 and 1.1 specifications. Bonzai is fully compatible with any system that supports USB. Furthermore, Bonzai will always transfer data at the highest rate allowed by your system's USB port.
Bonzai makes it easy to store, transfer and carry your files. Whether you're at home, at work, or on the road, Bonzai provides instant access to your files via any computer with a USB port.
Simply plug Bonzai into any USB port and the computer will automatically detect Bonzai as a drive. Now you can read, write, copy, delete and move data to and from your hard disk drive to Bonzai.
Use Bonzai to store your business documents, including Microsoft PowerPoint, Excel and Word files, and work anywhere you travel. Carry favorite digital pictures, MP3 music, video and audio clips and share them with family and friends. Even store games for a little fun between projects.
Bonzai is a breakthrough in design and convenience. With enough storage capacity to store the equivalent of hundreds of floppy disks or dozens of CD-ROMs, Bonzai gives you the freedom to carry all your files in the palm of your hand.
Bonzai features a sturdy and ruggedized case with non-slip rubber grips. The all-in-one unit requires no batteries, no external power, and no additional cables or adapters.
Bonzai is a plug-and-play USB device that is compatible with USB 2.0, 1.1 and 1.0 systems. USB is available in nearly every desktop and notebook computer made in the past few years. Bonzai works equally well with Windows and MacOS computers, with no drivers required (except for Windows 98 and earlier). Bonzai even works with USB hubs and USB keyboards so you don't have to remove other USB devices to access your files.
