Is this correct ? The fan on the Heatsink ( Tiger CPU Cooler ) blows air onto the heatsink against
sucking the air away from the heatsink. At the moment with the sides of the case the temps are 35C MB/59C CPU according to Asus Probe but are 10C lower in the Bios. Computer appears to be running find but I want to reduce the heat. I am thinking about drilling some holes in the side of the case.........roughly next to the CPU and putting a couple of extraction fans at the top of the case ( a full tower Aopen )
btw..........last thing I want to do is try and remove the current heat sink as I have already broke one of the plastic clips on the CPU holder. Maybe remove the fan and get a better fan for the CPU ?
Av7133
1200 T/Bird
Hercules 3D Ultra
256 meg 133 ram
Av7133
1200 T/Bird
Hercules 3D Ultra
256 meg 133 ram
