Simple program to tell me the current transfer speed of my wireless?
JEDI
29,391
2,738
i'm going to xfer files from laptop to desktop (40gigs) via my roommates wireless network.
is there a simple program that will tell me how fast i'm xferring stuff?
Cooky
1,408
Assuming you have Windows NT/2000/XP as the OS...
1.Open the Task Manager, in the Networking tab it will show you the network utilization.
2.The wireless program that comes w/ your wireless card may have something that shows you the stats.
JEDI
29,391
2,738
cool!
no, my wireless card (belkin usb) just tells me how many bytes are xferred, but not rate.
Edit:
now task manager sees my usb adapter as 11mbps. if it says 10%, does that mean 1.1mbps (~140kbytes/sec)?
thriemus
215
The 10% usuage is for control packets and packets for bulk transfers. This is how usb works, of the 12 MBits/sec available 10% is used by the usb controller and the 90% remaining for data hence 11Mbits/sec speed.
Open task manager and choose:
Networking Tab - View Menu - Select Columns - Tick Bytes Sent/Interval and Bytes Recieved/Interval.
If that isnt good enough for you then get Bandwidth Monitor Pro.
JackMDS
29,545
422
I might miss some big scientific innovation.
But how about transferring 10MB measure the time that it takes and multiply the time by
x4000.
I.e. if it took 5 sec. to transfer the 10MB it would take 20,000 sec. to transfer 40GB.
20,000 / 3600 is about 6 Hours.
:sun:
JEDI
29,391
2,738
bytes sent/received.. is that per second?
Micronaut
133
per interval - and you can control the interval - but yeah, it's roughly 1Hz at normal interval.
JEDI
29,391
2,738
how do i control the interval? and what do you mean 1hz? how does that translate to kb/sec?
JEDI
29,391
2,738
Found the answer:
update speed has three settings: High (twice per second), Normal (once every two seconds), Low (once every four seconds)
So if on normal, just divide by 2 to get per sec xfer rate
