Simple office DVR solution?
Slick5150
8,760
I have a need for my office for a simple DVR-esque solution that can record a TV feed every day, allow us to easily access the recordings/edit them, etc... Not sure if this is something to best look for a stand alone kind of device (somehting like the Monsoon Vulkano??) or a PC based hardware/software solution, but I'm open to ideas.
dclive
5,626
Any Windows 7 PC with a tuner (HD Homerun being an easy one) will do the trick.
Slick5150
8,760
I shouild mention, this thing needs to be REALLY simple to use. I won't be the one operating it, so it needs to be simple to set to record, edit the recordings, etc..
dclive
5,626
Yep, it is - and it's a very common DVR (free in Windows) ... so finding ppl that understand it is easy.....
Slick5150
8,760
Can you easily get the recordings OFF that Magnavox player though? Looks like you could only burn it on a DVD, then rerip that onto a computer?
