Simple Math Problem
Netopia
4
I wanted to make a little formula in a spread sheet to figure the height and width of widescreen flat panels.
Assuming a 16:9 ratio
Assuming that A^2 + B^2 = C^2
And an assumption on my part that I could add the 9 and the 16 to get 25... and then figured that the two sides would be 9/25 and 16/25 of the total length of the two sides combined (this might be where I went wrong)
I wrote the following:
A= squrt ( C^2 * 9/25 )
B= squrt ( C^2 * 16/25 )
I tried it with a triangle with the measurements of
A= 3
B= 4
C =5
A = squrt ( 5^2 * 9/25 )
A = squrt ( 25 * 9/25 )
A = squrt ( 9 )
A = 3
B = squrt ( 5^2 * 16/25 )
B = squrt ( 25 * 16/25 )
B = squrt ( 16 )
B = 4
So that seemed to work ok, but when I try it with real monitor measurements (like the 15.4 inch display on my laptop) I get crap.
I'm NOT a educated math person... I got stoned most of the way through High School Algebra I (in the 70's) and never bothered with anything beyond that (save Geometry). I'm not bad with math, just not versed in the language of it.
Where am I going wrong here?
Joe
CycloWizard
12,348
You have two pieces of information:
1. A^2+B^2=C^2 (Pythagorean theorem)
2. B/A=16/9 (known aspect ratio)
Solve 2 for B (B=16*A/9) and substitute this result into 1. This gives A=C/sqrt(1+256/91). Make a column for your values of C, then another with values of A using this equation. Then make another for B that is simply 16/9 times the result of the column of A.
Which brings me to my next point: don't smoke crack.
cmbehan
276
yup. This is how I would do it:
A=(B*16)/9
B=(A*9)/16
C=sqrt(a^2+b^2)
That means that:
C=sqrt(A^2+((A*9)/16)^2)
and
C=sqrt(((B*16)/9)^2+B^2)
Netopia
4
Thanks guys... I'll have to plug it in, look at it... and try to soak it in down to the understanding level! :D
Joe
