- Feb 12, 2013
- 3,818
- 1
- 0
I just can't quite understand the lens system.
E-mount or A-mount, full frame version or apsc version?
Get a used LA-EA4 and a Tamron 28-75 2.8. Not a bad combo and would focus faster than any other currently available option that I'm aware of.
not a bad lens at all but dam, that a-mount adapter bumps up the combo to ~$900, I might have to retreat back to the m4/3 hole that i came from...sigh.
has anyone tried the canon ef adapter?
Do you think I should just downgrade to a panny g7 or gh3 instead, I'm thrifty and those brighter fe lenses are just too expensive new or used.Go used.You can pick up the adapter for as little as $250, the lens for around the same price if you're lucky. Though, depending on how spendy you are going to be, you may consider the FE 24-70 instead.
The Canon EF adapters currently available are so slow (from what I've read) that you're better off manually focusing.
I can get a nice oly 45mm f1.8 for ~$250 or a really nice panny leica 25mm f1.4 for ~$400.
Or should I just suck it up and save for the fe lenses and keep the a7?
