Hi guys how are you?
I just bought a new CPU and a new Motherboard in a store and the store mounted it for me with my other pieces
But now i have a question, take a look at the picture:
The guy of course used the 24 pin connector and as you can see this MB has an 8 pin and one more 4 pin connector
Ho here is the question, he only used the 8 pin connector(red arrow), the 4 pin one is not plugged (blue arrow) with the PSU cable is it correct or should i plug both? If the answer is only the 8 pin why the MB have both?
I`m using here a 4770k @4.5 with a H110 2 GTX 780 in SLI and the PSU is a Coolermaster SilentPro Gold 1200W
Thanks
Thanks
