Originally posted by: dchakrab
Can you plug this in to a regular outlet to charge it, or is it 12V input only?
I'm thinking about using this as a backup power supply for emergency power in case of power outtages in india, probably in conjunction with a UPS...would that work at all, or is this totally different?
What's the difference between an inverter and a UPS system?
Thanks,
Dave.
An inverter converts DC power to AC power so you can plug things into a socket as you would do at home. This Sima inverter plugs into the cigarette lighter socket in your car (or you can connect it directly to a car battery) and gives you two plugs that you can use to plug things in while driving.Originally posted by: dchakrab
Can you plug this in to a regular outlet to charge it, or is it 12V input only? I'm thinking about using this as a backup power supply for emergency power in case of power outtages in india, probably in conjunction with a UPS...would that work at all, or is this totally different? What's the difference between an inverter and a UPS system? Thanks, Dave.
