SilverStone Lascala SST-LC10-B-M Case help!
aigomorla
21,034
3,514
can anyone tell me if the zalman 9500 will fit on a SilverStone Lascala SST-LC10-B-M Case ?
Case
I heard the scythe wont fit, but if anyone can prove wrong please let me know.
DerwenArtos12
4,278
That appears to use the same chasis as an older lascala I have and I can tell you that a Thermalright xp-120 with 38mm fan fit, it was very tight with that crossmember but it did fit. hope that helps.
aigomorla
21,034
3,514
thank you, yeah im gonna just look at the dimensions now and see if the 9500 will fit. I want this hsf because it blows air sideways which would be a better cooling method then having air blow down.
