I have a Silverstone Strider 600W power supply. I recently moved into a new home and after setting up my computer when I turned on the power supply the circuit breaker tripped.
I've narrowed it down to the power supply by removing it from the computer, disconnecting all the cords, and making sure it was the only thing using the circuit i.e. unplugged everything else in the house using outlets on that circuit. Still, as soon as I turned on the power supply the circuit blew. I also tried using different outlets on the same circuit with the same result.
I tried using a 1200W hair dryer and a 520W OCZ power supply on the same outlet and neither of them would trip the breaker. This leads me to believe I have a faulty power supply. However, I tried the power supply in a different room that uses a different circuit and it did not trip that breaker. So, I don't know what's going on. It sounds like I have a faulty power supply because I've tried tons of other appliances and nothing else trips the circuit but that doesn't explain why the power supply works on the other circuit. Any advice?
