- Jun 21, 2005
- 12,086
- 2,281
- 126
I've been running distilled water with a silver kill coil in my loop (1 CPU block, 2 GPU blocks, 3 rads, 1 res) for the last ~5 years. I've only disassembled and refilled that loop once in those 5 yrs. As far as I could see, I haven't had any corrosion or algae issues and my soft clear tubes have stayed clean.
I'm planning on running a much bigger reservoir than I do currently when I rebuild the loop in about a month.
My question is, how much silver in the loop is "enough" to prevent algae? Should I have a couple of coils of the stuff in the reservoir? Is having the kill coil just in the reservoir enough to prevent algae in a rad far into the loop?
I'd like to avoid premixes and biocides/etc if I can. I wouldn't mind putting say propylene glycol in the system if that would be recommended over distilled+silver coil.
