Originally posted by: Schadenfroh
what vivan said....
as soon as you put thos voodoo2s in place and apply the drivers and run the cables, your 9800 pro will turn into a 2D video card and the voodoo2s would do ALL of the 3d work.
This is not true.... back in 97-99 or so, I had Nvidia's Riva128 and TNT1/2 cards paired with Voodoo1 then 2 later on... I set it up to do Direct3D on the Nvidia cards, while Glide on the voodoos of course. Where did you get "the Voodoo2s would do
ALL of the 3d work" ???
forgot about the glide rigs like that, you can select an adapter, but that is what the voodoo2 was designed to do, take over the 3dwork from the card it was attached to.
anyway, primiumG, DONT DO IT
