Silly question, but need help. IE 6.0 related.
edblor
7,921
I use IE 6.0, patched up to date completely...I hope;)
Anyways.....When I right click a link, and "Open in New Window", that window opens to my default size. No biggie, but the default size right now is almost full screen. I would like to change that:)
I remember in the past, you would hold the shift key while closing the window. Does that still work? I tried it, but it did not. Is there a reg hack to change this setting?
Help!
Thanks guys!
Edblor
Rkonster
1,737
IE just remembers the size of the last window that you closed.
EDIT: Oh, when you open new window, it just uses the size of the window that you are using.
Ryan
edblor
7,921
1stly,
TY for the reply:)
2ndly,
The main window from where I am right-clicking a link, is maximized. Even when it is not maximized, and I crop it to another size, it still remembers to open it almost fully maximized (this happens to be the window size I am trying to avoid). All my windows do this (even when I start XP, and open an IE session, i.e, the 1st IE window).
I would like to have it remember to open up like in half of the window. You know, so I can see what may be behind that particular window!
Any other ideas peeps?
Edblor
Double0Three
13
First of all, I'll start by saying sorry, I don't have a solution to your problem.
I would like all windows to open in full screen mode, but they always open in that "almost" full screen mode. It's rather annoying when I go to click the X at the top right, and have it close the window behind it instead if the window I'm currently viewing is not "true" full screen.
There has to be a fix!!
edblor
7,921
That is exactly what I am talking about:(
The "almost full screen mode"....arrrghhhh!
Anyway.....there has to be something!
At work (where I currently am), right-clicking opens windows to the same size as the parent window. But, what about new windows fromthe IE button?
Edblor
Reg
Isn't that the truth. I hate it.
