EvilManagedCare
Please be gentle, I am rather new to cooling options and PSU issues and I apologize this may be a bit wordy. I just want to make sure I have everything covered. Anyway, I have an AMD 64 3700+ processor using the stock cooler. This replaced a 3000+ that had also used the stock heatsink and fan from AMD. Both of these fans seemed to make a strange noise, almost like it would rev up, then resume the previous speed. This would proceed while the PC is on. I do not have Cool n Quiet enabled, so I am surprised the fan seems to be varying its speed. I've run Sandra SiSoft and it periodically throws out warnings about the CPU fan, but I was told by some others on this forum to ignore it as it evidently will do that for fan RPMs below a certain amount. I have fan speed settings configured in BIOS to vary speed depending on temp. The strange noise occurs regardless of this being on or off.
I have had no system instability and my temps are not abnormally high. When I check the voltage readings in the BIOS, a couple of them will change by about 0.03 V (sorry, I can't remember the specific readings or voltage being measured). For example, the CPU voltage will go from 1.50V to 1.53V intermittently, usually like every couple of seconds. This PSU is of ample Wattage and is only under a year old. This strange phenomena has gone on since I put the system together last November.
So, I'm wondering a few different things:
1. Should I get a new PSU? (I'm inclined to say no simply because I'm not having any instability and my temps are still acceptable so the fans seem to be working correctly)
2. Is there an adapter that can plug in from the 4 pin connectors from the PSU to the 3 pin connector on the fan? I don't care if the fan slows down or speeds up based on temp, I just want it to cool the CPU properly and stop making that irritating revving noise.
3. Should I just get a third party CPU cooler?
Thanks in advance for the help.
