- Dec 23, 2004
- 1,569
- 3
- 81
I am building a low-end A8N-SLI system that won't require super cooling. I plan to get a case with a 12cm fan front/back, and mabey a side fan (probably 8cm).
The fans - can I just plug some cheap ones into the mobo? Like these:
http://www.primepc.jp/goods_pc...ode=71&sbrcode=132
Or do I need special fans/conectors? Do they automaticaly adjust speed?
Thank you!
Thank you!
