- Jan 15, 2005
- 51
- 0
- 0
Looking at the specs of the SilenX Fans.. 120mm is 58cfm while generating 14dBa, and the 80mm produces 27cfm with only 14dBa.. are these specs truthful? Thats really nice.. If so, I'm considering getting a few of those.
Originally posted by: Chopstick217
I too am thinking about picking up some silent x 120 mm fans. However, im quite skeptical about the idea that the fans are only 14 dba while blowing 58 CFM.
You should be skepticalClearly SilenX is rating their fans using some BS testing protocol.
Originally posted by: CraigRT
it has to be horse poop... even air turbulence noise will amount to more than 14dba, regardless of how quiet the fan blades and motor are.. but that's just what i think....
Originally posted by: Amol
so Panaflo's are the best?
For 80-92 yes. Some have said the 120mm Panaflows are as good; but I haven't tried any.
what about nexus fans?
I have some 120x25mm Panaflo's on order... They should arrive on Wednesday by the time I get home. Depending on the time, I'm going to try and install them before the computer starts recording shows... They can't be any worse than the enermax 120x25mm fans that I installed over the weekend. Even on the lowest setting those things are LOUD...
Rebadged (expensive) version of Yate Loons. They very quiet sleeve bearing based fans, but not as durable/reliable as ball bearing or Panaflow (hydrowave) fans.
All Panaflo's are 38mm deep. Hopefully they will still fit in your case
Ed
Ed
Really??? Where did you get that bogus info from? I actually HAVE a 92x25mm Panaflo fan. The 120's I have on order ARE 25mm deep/thick...
Next time, tripple check your facts before you make a statement like that.
Panaflo fans use a plane bearing with a twist; they use the shaft rotation to keep oil flowing inside the bearing. Nothing special really.
Ed
