My main concern is noise level, so I'm aiming to get a very quiet setup. I've already purchased the main components, but I need advice on what kind of case fans and CPU cooler I need to get, and whether the CPU cooler will physically fit with my current setup.
Case: Fractal Design R3
CPU: Intel Core i5 2500K
MOBO: Asus P8Z68V-LX
GPU: Gigabyte GTX 560 Ti 448
Sound card: HT Omega Striker 7.1
SSD: Corsair Force Series GT 240 GB
HDD: Western Digital 500 GB 7200 RPM
RAM: Corsair Vengeance 8 GB (2 x 4GB) DDR3 1600
PSU: Corsair Pro Series Gold AX650
CD-RW: Standard, cheap ASUS CD-RW
So, I've already purchased the above components. I need to place an order for some case fans and a CPU cooler. I'm looking for quiet and whether these will fit with my current setup.
Could you please rate my current build and also provide me with some recommendations for the fans and cooler? For what it's worth, I'm only going to be playing games and the odds of me over clocking anything are pretty much 0%. I only want the aftermarket CPU cooler because I was told that the stock one sucks and is very loud when you start playing games. And since I'm not looking to over clock, having an ultra-quiet cooler takes precedence over actual cooling efficacy.
Thanks!
Thanks!
