I am planning to replace the crappy (and loud) stock coolermaster fans in my cosmos 1000 with one of the following fans:
Scythe Gentle Typhoon 120mm fan; 500rpm, 5dBA
Scythe S-Flex S-FDB 120mm fan (SFF21D); 800rpm, 8.7dBA
Scythe Slip Stream (Kaze-Jyuni) 120mm; 500rpm, 7.5dBA
I am leaning towards grabbing 2 or 3 of the S-Flex fans, but was wondering if they would be noticable noisewise compared to say the Slip Stream running @ 500rpm. I would like super silence so I will only consider the lower rpm case fans. The S-Flex has more airflow and apparently a much longer mtbf rating of 150,000hrs vs only 30,000hrs on the Slip Steams. The Gentle Typhoon has the quietest noise rating but I am not so sure about it.
Any suggestions or recommendations? Thanks.
