Silent CPU Cooling
Angracey
36
I work at a local computer shop and am trying to find an ultra quiet solution for out new systems.
One option i've observed is replacing the heatsink/fan with the Swiftech MX462U without a fan.
This seems to quiet the system quite a bit, but my question is would i require a cooling fan on the heatsink.
The CPU's we're using are Athlon XP 1700 and 2100 right now
AC3 and one case fan.
Any suggestions would be a great help.
Thanks.
Angracey
36
Ah, ok.
What i'm looking for is best price/quietness combo.
Not really concerned with CPU temperature, just has to be acceptable.
LoverBoyJ
992
One thing you could do is lower all the fan voltages, instead of using the 12V, plug it to the 5V. This will lower the fan speed of the fans.
godmare
5,121
Many case fans won't start at 5volts, you'll have to go with 7. You'll have to see what temps you get with a 7volted Panaflo L1A on a 2100, especially if its a palomino.
Eug
24,143
1,793
Fortunately, my Panaflo does. I found most of my cheapie case fans do not however, even when brand new without dust.
OulOat
5,769
Originally posted by: Angracey
Those items look great, but is there a solution without a heatsink fan?
Thanks again.
You might be able to get away with the Zalman flower hs, those are advertise as without fans. But those are also in the $30+ range and are quite big. However, if your cases have ducts above the cpus like dells, you could probably get away with just that fan. 2 fans (duct and PSU) in a system is pretty quiet.
Edited for errors
jarsoffart
1,832
Thanks again.
You might be able to get away with the vantec flower hs, those are advertise as without fans. But those are also in the $30+ range and are quite big. However, if your cases have ducts above the cpus like dells, you could probably get away with just that fan. 2 fans (duct and PSU) in a system is pretty quiet.
He means Zalman, I think at least. The SK-7 with the quiet NMB from SVC or a undervolted Panaflo should be able to keep a 2100+ at a safe temperature. Along with a Antec TruePower, the system should be rather quiet. For the video card, cool it with a Zalman HPxxxxxx.
