Originally posted by: Cook1
Originally posted by: Tiamat
How did you fit 2 80mm fan in that LianLi peripheral?
Specs are wrong, only takes up 2 drive bays and has 2 fans.
Ahh! No cd drives?
In any case, your set up has plenty of good airflow. You may not even have to plug in half of your intake fans. One fan on top, one fan on bottom.
If you want all your fans going, i would get Panaflo L1A 80mm, and some sort of fan controlling device - obviously not a 5.25" bay one since you dont have the space for it. 7V should suffice. place all 4 intake on 7V (low setting on your lian li case).
I guess you could put the bottom 2 on Low, and get 2 zalman fanmates for the top 2 panaflos. Your psu probably sucks more than 50cfm, and your aft fan probably you can keep at 12V, or 9V, or 7V if you are a quiet computer guy.
At 7V i estimate the panaflo to move maybe 12-15cfm at best. A very very rough estimate would be 48-50 cfm intake, and 70cfm exhaust. Thats pretty good as I find with negative case pressure comes lower temps. Just place dust filters on your intakes.
