- Aug 9, 2007
- 51
- 0
- 66
Howdy.
I have had this Compucase box for about a year now, and it came equipped with some generic 12 cm fans on both front and back of the case. Lately I've been thinking about switching them to something more silent and hopefully a bit more effective as well. Any suggestions? I hear Noctua is good, and some reviews of NF-S12-800 for example say that it doesn't make a peep and does the job well.
In addition to that, I'm looking for a way to silence my hard drives a bit. I read about NoiseBlocker CoolSwing Silver things that are screwed on the sides of HD and slide into a 5.25" slot. Supposedly cools down the HD and eliminates some of the resonance. Any opinions of products like that? I'm pretty clueless about these, didn't even know stuff like that excisted before yesterday.
I'm also wondering about the AMD stock cooler. I'm satisfied with the performance of it (non-overclocker) but is it loud? Because I can't tell. Having used the same case for my earlier system and current X2 5600+, the fan is possibly drowned in the other noise. But if I silence the case with new fans etc, will the stock cpu cooler stand out after that? Any ideas? Is the Noctua NH-U12F any good, for example? I looked into Zalman's CNPS9500-AM2 as well, and a little mixed reviews as far as the noise goes. Other reviews say it's silent, but others disagree.
And finally, any general hints to silence the case would be greatly appreciated.
