Significant difference between Asus/EVGA in terms of quality?
Cymera
114
Hi, I'm building a new system with a 680 and the store I'm purchasing from has an ASUS 680 at the same price and with the exact same stats as an EVGA 680 I was going to purchase. The EVGA has to come in from EVGA and would take up to two weeks, while the ASUS is in stock atm.
I have an EVGA currently and I'm very happy with it, my question is if there is a significant difference in terms of quality in video cards between EVGA and ASUS that I should consider when deciding between the two. Also, both have a 3 year warranty.
Thoughts?
chimaxi83
5,457
63
101
Quality, no. Both are reference cards, I'm assuming? They're exactly the same minus the look/sticker on the cover.
Some people will say EVGA will be better because of their RMA process, but that's about it.
kalrith
6,628
7
From what I've heard, EVGA has the best warranty...something about replacing your card with one that's as good or better if the card is no longer made.
Fallengod
5,908
19
Evga changed their warranty policy recently and its even better than it was before so....
Quality, remember, Nvidia makes the video cards... :p
Some people, you mean like all people? :p
Meghan54
11,684
5,228
They also have a lifetime warrenty which is a win
While you can try to make that blanket statement, it's not completely true. NONE of EVGA's GTX 680 cards have a lifetime warranty. Longest warranty available is 7 years, and that's only for the nominal additional cost of $50 from EVGA......
3DVagabond
11,951
204
:thumbsup: EVGA's standard warranty is 3 years now.
