Sidewinder 3D Pro "Not connected"
Darkhound85
13
I'm about ready to smash my PC here. System specs are : XP2800 Barton, 1Gig DDR333, FX5700 Ultra, ASUS A7N8X-X, Windows XP Pro
For the last 90 minutes I've been trying to get my old Microsoft Sidewinder 3D Pro to work. I have it connected to the gameport on my soundcard. It used to work on my old motherboard's gameport, but not my old soundcards. I have different motherboard and soundcard now, and the mobo doesn't have a gameport. So I am trying to use the port on my new sound card.
However, it keeps saying "Not connected" when it is. I've been trauling the internet trying to find out how to get the damn thing to work. To begin with I had two instances of "Standard Gameport" in Device Manager. I removed one but it kept appearing - so I checked the net to find I had to disable my onboard gameport. So I did that, and onboard midi (aswell as Onboard sound which was disabled before). Now one instance dissapeared, but now on the other one (which I'm pretty sure is the one on my sound card) I'm getting "This device cannot find enough free resources that it can use. (Code 12)" and under resources I'm getting "Input/Output Range 0201 - 0201 not available." and it wont let me change anything. So, I took another trip to the internet and read to check whether it was sharing resources with any other device by going into device manager and View>Resources by connection. So I did, and there it is under I/O on 00000201 - 00000201, all buy itself. Nothing else is sharing this resource. I have restarted between attempts at solutions but nothing has fixed it.
Anyone have any ideas? I am thinking of just buying a USB pad while I have some hair left, but I would rather get this one fixed.
Thanks In Advance
ViRGE
Elite Member, Moderator Emeritus
167
The 3D Pro was a finicky stick, due to a new technology MS implemented at just the wrong time. With the 3D Pro, Microsoft made it a digital "self-polling" joystick, right at the same time that sound cards made their MIDI ports "self-polling" too(the CPU previously did all the polling). The result was that the 3D Pro is as finicky as hell, since it was expecting a CPU poll, and not getting it, requiring nothing short of voodoo magic to get it all working. You're best off just ditching the 3D Pro, and getting yourself a USB Precision Pro(not the PP2, though); going the USB route skips all the stupid polling issues.
mechBgon
Oct 31, 1999
30,699
Set it up as a generic 4-axis stick and it'll work. You'll lose the base buttons. I :heart: my Sidewinder 3D Pros, they'll pry 'em from my COLD DEAD FINGERS! :evil:
Darkhound85
13
It wont let me set up any pads now, its saying "Your Gameport or Gameport drivers are not properly configured, Please Consult the Device Manager"
AARRGHH
AsianriceX
1,318
Wow, I remember using the 3D Pro ages ago to play Terminal Velocity and the numerous Star Wars space sims. I can't believe someone is still using such archaic technology :D
Darkhound85
13
Well I'll tell you: considering there are so few PC games that require a pad, I didn't particularely want to buy a new one, and i got this one free from my dad about 3 years ago.
