EvilSponge
Hello all,
I am using a Antec900 and I have a question about fans and CFM. I recently replaced my thermalright 120 ultra extreme cooler with a Zerothem NV 120 as the thermal right would not allow me to run a side panel fan which really helps with temps in my experience. In any case I have my Q6600 running idle at 35-36c with speed step enabled. and 66-67c prime95 full load 6 hours. I experimented with three 120mm side panel fans.
1) Thermaltake 120mm fan 78CFM Loaded temp 68-69c fully loaded 2 hours prime95
2) Thermaltake silentcat 120mm fan @ 67CFM Loaded temp 68c fully loaded 2 hours prime95
3) Scyth Flex 120mm fan @ 42CFM Loaded temp 65-66c fully loaded 2 hours prime95
All temps monitored with latest core temp program
Now I thought a higher CFM fan would lower temps not raise them?
Why is the lower CFM fan cooling the best?
If anyone has an answer I'd like to hear it.
Thanks,
-sponge
BTW the Zerotherm with side fan is 2 degrees cooler than my thermal right without sidefan
Thanks,
-sponge
