merlion
Corsair Carbide 400R case with Z68 mobo using onboard graphics, so no video card heat. CPU cooler is an Antec Kuhler 620 with Cougar PWM fans in push/pull. The case also has two Noctua PWM fans on the top panel for exhaust, and the stock rear Corsair 120 mm fan moved down to the bottom panel as an intake. The stock two 120 mm front panel fans are also intakes.
Would this side fan be better as an intake for cool air since there is no heat needing to be exhausted in that area from a video card?
