- Mar 22, 2006
- 14,264
- 3
- 81
As I'm planning my next CPU build one of the things I'd like to focus on is good air cooling, but without compromising silence. Since I keep my desktop in my bedroom, frequently listen to music on open headphones, and spend a lot of time at my computer, I wanted to keep the noise level as low as possible without also compromising cooling ability or spending too much money. The Fractal R3 is designed for silence so it should be much better than my current Enermax Phoenix.
I've purchased four Scythe Slip Stream SY1225SL12M (1200RPM mediums) to use as my case fans, since they only cost $2 more than some Yates. I have a Hyper 212+ for a CPU cooler, which I think I'll keep the fan stock on and keep PWM on silent or low control. I also picked up a second 3-fan PCI bracket fan controller to use alongside the provided Fractal one (interestingly, it's exactly the same, but branded Xigmatek). Each will control two case fans.
I'm planning to use two intakes on the front, a rear exhaust with CPU fan pointed towards it, and PSU as a pseudo-exhaust. I have one more fan and another intake to fill (for positive pressure). I can put the last Slip Stream on the side, or on the top, in a horizontal position. I would prefer the top but since the SS is a sleeve-bearing fan, I'm afraid it's going to wear out prematurely. But I've also read side fans increase noise a relatively considerable amount. So what should I do?
TL;DR - Have Scythe Slip Streams, need one more intake fan. Should I put the last one on the side panel or on the top?
