Side case fan opposite from the CPU, blow in or out?
2Dead
886
Hi all,
I have a case with a fan(80mm) opposite from the CPU and I was wondering if it would be better for the fan to blow outside air in or the case air out? I do have a 120mm fan on the back blowing air in and an 80mm fan on the front blowing air in? Just wondering which would cool the case and improve air flow better?
HardWarrior
4,400
23
It should suck air into the case. But you might want to consider a filter. The 120 on the back should exhaust, BTW.
2Dead
886
That's what I thought. It came with the case blowing out but i switched it to blow in. I was wondering what where others' experiences with this.
PS. There is also a open grill in the case by the graphics card to let air in.
HardWarrior
4,400
23
Depending on where it's located and how powerful it is, a door fan can do wonders for a forced-air cooled case. The one downside is the huge amounts of dust it can intake.
2Dead
886
There is a filter there. Its not very powerful but it does get more are in. It's diectly opposite from the stock AMD cpu fan and heatsink. Looking through the fan I can see the cpu fan and heatsink
BonzaiDuck
16,127
1,741
Most of the time a side-panel blow-hole duct would suck air in and onto the CPU cooler. I've cut blowhole ducts in most of my systems, but I've been re-thinking this lately. Let me get back to that thought in a minute.
Just for the matter of noise, it would be better if you can duct the side-panel blow-hole to the top of the CPU so that the CPU fan can only draw air from the blow-hole. Then you can dispense with the side-panel fan, which is bound to be noisier, just for its proximity to the case-panel.
Also, you say you have a rear intake fan. Usually, intake fans are deployed in the case-front, and exhaust in the case rear. This is not some rule-of-thumb, but you should balance the air inflow and air outflow in the case by getting your fan CFM specs, making whatever linear extrapolations are necessary for the speed you intend to run each fan. Filtered intake fans will not meet their full CFM spec even at top speed, but you should be able to match intake and outflow approximately.
Now back to the other issue. I now use a foam-art-board motherboard duct, which forces air over the motherboard before it is exhausted. Part of the logic of using such a duct involves having case intake fans with high throughput. The duct separates new "cold" air from "warm", and the pressure outside the duct should be at least as great as what it is inside. I've been able to eliminate much noise by closing off my blowhole and tuning up my front-panel intake fans just a tad. The net change in noise seems to be on the loss side, and that's good.
2Dead
886
Sorry, that was a typo. the 120 is blowing out. The 80mm side fan has a sort of duct which is only a few cm away from the cpu fan forcing air there.
