I have an Antec SX1000 case, and I replaced my case fans with Panaflos, and my power supply fans with the Antecs that came with the case. When I did that, the noise level went down a ton, but my cpu temps rose from 34 degrees idle to 38 degrees and my idle case temps went from 25 degrees to 28 degrees. My heavy load temps are all about 3 - 5 degrees higher than the idles.
The question is, will a side fan or a top fan help? If so, what kind should I get (make sure noise stays low)? And finally, should the side be an intake or an exhaust (Different people say different things about this one)?
