Boyo
I'm not sure how familiar anyone is with the FilterRight and the A.C. Meshx filters, but I have a question that so far I have not been able to find an answer to.
I have a 120mm side air intake and a FilterRight filter, which fits on the outside of the window and attaches to the fan inside. It's not exactly striking to look at. So what I wanted to do was replace that set up with a grille, and use an A.C. Meshx filter under the grille for dust.
Does anyone know which filter is rated better, or if the A.C. Ryan Meshx is too restrictive? I'm trying to find something that will allow me to add some better aesthetics to my side window. Here is a page that shows both the FilterRight (FR120-CL) & the A.C. Ryan Meshx (ACR-FG0731). Filters
