sick of running out of memory - should I go W2K???
AMD4ME2
664
Ok.. I get tired of my memory leaking out all over the floor.. I mostly use this box for gaming and light web developement work. I have the upgrade CD to win2k.. How
will this effect my gaming? and what is the likelyhood of major problems with the following setup.
Abit KT7A-Raid
Geforce 256 SDR
SB Live!
Netgear FA310TX 10/100 NIC
20.5gig WD 7200 ata66 harddrive(on highpoint controller)
256meg Mushkin Rev2 Cas2 Memory (I like stepping in the expensive memory that forms around the floor by my desk)
I was hoping that my new system would help to combat the memory leak problem but apparently not..
Thanks,
Wik
2,284
I can't say that all games work fine in Win2K but so far it is the case for me, but I usually only play CS and a little UT and Q3. Nascar and Mid Town I have tested also.
Go to Win2K though. Your system is crying for it. But do not upgrade. Install fresh using the upgrade disk. If you have questions about this ask.
AMD4ME2
664
well I tried an upgrade a few minutes ago.. and it couldn't find the drivers for the highpoint controller.. even though I supplied the floppy and CDrom that came with my abit board. Why exactly should I not do an upgrade? I cancelled out to do a bit more research on the situation.
travisio
220
I am using win2k on 3 boxes (1 adv. server). I have ran most games fine on all these machines : c&c - tiberian sun, CS, project IGI, vietnam, sims, rogue spear, etc. I would upgrade to win2k because it never locks up (once you solve vid card issues like I had to do). It is a secure os that has security also supporting directx 8+ You can get good frame rates with the right tweaks. I have had about 3 GPFs running win2k. I have never had a program totally lock up win2k. Also more and more hardware manufacturers are coming out with win2k drivers. I also like being able to have more control over devices and their drivers as opposed to NT 4. I would recommend win2k personally, but thats just me...
AMD4ME2
664
well im big into games.. but I would give up a small amount of performance so that I could get up and set down at the computer and open IE without getting "not enough memory to run this application, shut down some programs and try again" :disgust:
ammarrafiq
10
why dont you use a program like maxmem or rambooster..? yesterday i noticed some slack and ran maxmem.. found out i had only 2(!) megs free.. one aggressive scrub.. 91 megs free... :)
AMD4ME2
664
yeah ive done the memturbo2 thing before.. I may do that till whistler is released :)
