SI-97A socket A clip? Please help.
clemsyn
534
205
HI, recently acquired an SI-97a and it came with this clip...is this the right Socket A clip for the SI-97a? Please help..
<img src="http://i12.photobucket.com/albums/a240/clemsyn/socketclip.jpg" alt="Image hosting by Photobucket">
Ping to the Pong
217
from the reviews on this cooler, the clip seems to be somewhat different than the clip you have. Im not sure it will work correctly or not. Where did you get the SI97? if you bought it from a online store you can request a replacement, if you bought it used or from a private seller, good luck....
GalvanizedYankee
6,986
IDK, but would guess that is an early model retaining clip.
Go to ThermelRight's site, look up your HS, at the bottom of that page will be reviews
and in these reviews will be pics of the current retaining clip.
I would email TR w/your pic attached. They are very responsive to inquiory and they
*might*send you the newer clip.
...Galvanized
clemsyn
534
205
thanks...talk to the support staff and said it's not a clip for si-97a..thanks..
