Shuttles and USB Floppies
dswskinner
8
Hi all
I'm new in the world of SSF and i'm planning the system that i'm going to built to be my HTPC.
My current vision is:
One of the Springdale or Canterwood cubes (depending on when i buy, what they cost and what the differences between the 2 are)
Pentium 2.8c
512Mb 400Mhz ram (i assume with springdale and canterwood it is better to have 2 sticks of 256?)
2 80Gb S-ATA drives RAID 1
One of the Radeon AIW cards
A Sony DVDRW combo drive.
My question is: is don't want to mess us the front of my case by using an internal floppy drive. So have decided on a USB drive that i can just hide in a drawer. I know the XPC's can boot from USB floppy so bootdisks are not problem.
However, when installing Win2k/XP on an XPC. Do you need to hit F6 right at the beginning to give the install the drivers for your Hard disk controllers (i currently have to do this as i am using an old Abit BE6-II)?? If you do need to do this, does the install recognise the USB floppy as a regular floppy.
Many thanks in advance.
Teva24
59
Win2k/XP detects the HD controller just fine, you don't need to hit F6 to install specific HD Controller drivers (At least for a SS51G and a SB51G)
Although you can update the drivers once the os is loaded if you want.
Running Floppyless myself.
