Shuttle Will Not Post After BIOS Update HELP!!!
lsamorph2
260
Ok I flashed my Shuttle SN95G5 V2 with the lastest bios update from the following webpage:
Link
And now it will not post at all. It turns on. But I only get a black screen. Any idea what happen to it.
Any help will be greatly appreciated. Thanks
btcomm1
943
Try to reset the cmos, if that doesn't work then if you have the option to RMA you probrably should since I don't know if there is anything else you can really do, it just may be dead.
Captante
30,357
10,884
You should be able to contact Shuttle & have them send you out a pre-flashed BIOS chip with the latest version already installed.
