Shuttle sn45g help.
sisq0kidd
17,043
Hey guys. I received this barebone system and installed:
Athlon 2200+ thoroughbred
Geforce fx5200
Crucial 256 ram
etc.
First time didn't boot up.
Reset cmos and everything booted up fine.
Went into bios, changed the fsb to 133 and restarted.
After restarting, the screen said something like "do not reset, updating components" or something to that effect.
System stayed on that screen for over 5 minutes.
I reset and now system will power up, but no post, no video no beeps. Reminds me of when a cpu or a motherboard dies. Tried clearing cmos, insert key, diff components, etc. No go. Any help?
DAPUNISHER
31,687
31,542
I had the SN45G, great SFF for its time.
Your symptoms sound like a corrupted bios; 1st I'd set the pins to clear CMOS, pull the battery, hit the power button a couple times, let it sit an hour or so, replace the battery, replace the pins, and try to boot. No go? I'd try hot flashing the bios in another board, if you have, or can get your hands on, 1 that is compatable with the chip.
