Shuttle SK43G Power Supply
KayKay
I am considering purchasing the Shuttle SK43G. The Power Supply is listed as 200W
Naturally I went to the http://www.jscustompcs.com/power_supply/Power_Supply_Calculator.php?cmd=AMD
power supply calculator. It recommended 234 W
Will this work? here is what i want to Put in it:
AMD Athlon XP Barton 2600 (FSB 333)
1 512 Corsair Valueselect Stick
6600GT AGP (needs extra molex connector)
WD Caviar 200 GB SATA
NEC 3520 DVD+/-RW
What do you think? Will it be okay?
Those powersupplies in the shuttle SFF cases are really nice for their rated wattage. In my opinion you should be fine. I've heard of much more demanding rigs than that one running on SFF PSUs.
sounds good. but the shuttle cases that support more demanding rigs have better power supplies.
i'll give it a try, does anyone else have experience with this particular shuttle model?
