- Jun 4, 2003
- 1,081
- 0
- 71
I have the Shuttle XPC SB61G2 and I was hoping you all knew the fastest cfm an that I could replace my system fan with without any modding. I used to have a 2.4c in it running at 3ghz with a slot fan installed, when I took out the slot fan I had heating issues. I have a 2.8c now running over 3.4 ghz stable and am probably going to have the same amount of problems when I take out the slot fan. I'm planning out taking out the slot fan because I want an Audigy 2 because the onboard AC97 sucks. I'm also running a 120GB WD SE, Lite on dvd cdr combo drive, and an aiw 9800 pro, incase there might be some power issues when replacing the fan.
I know that is a mouthfull, basically just need to replace the fan that cools the heatsink to the heatpipe. I'd like the best cfm fan that I can hook up to the motherboard like the one is now so I can run it at full speed all the time. Thanks in advance!
