Shuttle help, no video
scoobytwo
55
I have a Shuttle SD32G2B and a few days ago it stopped working.
Here is what it is doing:
1. When I power it on it will shut itself off about a second later, then turn back on by itself
2. I get no video signal at all whether using the onboard video or a x1300 pci-e video card
I have reset the cmos numerous times with no luck
I figure it is either the cpu, ram or shuttle itself, but I was wondering if anyone else had this issue with their shuttle and what they did to fix it, thanks
RamIt
777
186
Had the same problem with my sb61g2.
Try hooking up a regular atx power supply to it to see if the power supply went out.
Jesta
346
Had a similar problem with an SB83, turned out to be the seating of one of the sticks of ram. Pulled them out and swtiched slots and it worked fine. Something to look at.
