I got annoyed with my shuttle's noise, and decided to create my own cooling system for it.
I removed the heatpipe, and attached a regular cpu cooler (Swiftech MCX4000 and TMD fan) to the CPU and modded the exhaust to use a standard 92mm fan. I'm going to add a side intake probably on the right side, opposite of the AGP area, and close to the memory/drives (just enough space for an 80mm or 60mm fan...)
I haven't tested my system yet (waiting for another HD to use for this "leftover" pc) but hopefully it will cool better and QUIETER than the heatpipe system.
Now....who else has modded their shuttle to a more "conventional" cooling situation (standard HS, exhaust in the back)? Did it lower your temps?
The biggest heat producing areas are definately the drives and the GPU area, especially if using a soundcard like an Audigy or other PCI card that gets fairly hot. The PSU also produces a LOT of heat. Has anyone come up with a way to provide better cooling for these areas, aside from getting cooler drives 🙂 ?
If the whole thing works....then the next thing I'm gonna try is to stick a Zalman cnps7000 in there.....that thing weighs more than the case!
