Shuttle AV49VN apparently dead
freebus52
I had purchased a new AV49VN MB, with a P4 2.8G, 512MB ram, Chaintech FX5700 video card and Powmax LP6100D 400 w power supply. Only the fans work (CPU, videocard, PS). No beeping, no video, no drive access. Four second power down timer on power switch works. It seems like I have built a very expensive four second timer. MB and CPU have been replaced but exactly the same symptoms. I have even tried another used power supply. Next step is to try a NEW 450 watt supply. Yes, the P4 4 pin ATX connector was connected. I have built many systems without issue. Time to give up DIY?
o1die
4,785
Have you tried posting out of the case, with just the video card, one stick of memory, cpu/heatsink. I've never had a new board doa, but maybe I'm just lucky. Be sure your power switch is connected correctly. I would also try a different video card.
freebus52
It turns out this may be an issue of the motherboard not accepting "Prescott" CPU's, as opposed to Northwoods CPU's. I can not find this on their website, however their tech support contacted me with the info.
