Shuttle AN35N Ultra 6 channel Audio
mect
2,424
1,636
I just picked up the Logitech z-640 speakers and set them up, but the rear speakers aren't working. I've set the speaker setup in windows to 5.1 sound and checked the box for rear speakers to the line in and the center speaker to the mic, but still nothing. Is there anything else you have to do to make the line in and mic jacks work for the rear and center speakers, or is there anything else I could be doing wrong? Thanks
someone16
522
9
What are you using to check the sound? FYI, with normal music there woint be sound out the rear. Try it with something that does surround like divx videos.
HKSturboKID
1,816
I am having the same problem. When playing games, no sound in the center and rear channel. I ahve the same motherboard and same speakers as well. What kind of settings you have to do to get the sound to work for rear and center?
xbassman
1,243
If I remember correctly your board has the Realtek audio chip.
Download drivers here.
All will be as it should! :)
