Shuttle an -35 N ultra 2500 M problem
Jul 5, 2004
131
hello all this is what i have
Shuttle an35n ultra 1.1 rev ( laterest bios)
amd mobile 2500 barton
mushikin ddr400 at it's speed 2-3-3-6
cheap 300 W power. by rosewill
firewire card, wireless card, radeon 7000 pci
Prime ide wd 80gb, wd 120gb
sec ide dvd rom, cd-r drive
fans...2 intake 2 exuast fan... 32C / lead ~50C
my problem.
Once it's on it works just fine for hours.
I over clocked before to 2.2G ( 200mhz * 11)
or 2.3G (200mhz * 11.5)
But some times it just wont boot up right, The bios start at the safe mode
displaying
"amd mobile 600mhz..."
What i do right now to get by is....go into bios and save and exit.
when it restart it seems to work SOMETIMES.
Am i doing something wrong with voltage???
for the chip i mess around 1.7 volt~ 1.775 volt...
for the memory i only have 2.6 and 2.7 volt option ....
Do i just have a bad motherboard??? how come my computer is stable once it's on
(ex. setting - 11 X 200 1.75V 2.7V for the ram.) but i can't boot it up????
KGB
3,042
kidd,
Welcome to the Forums! :beer:
Are you saying you only get these problems when your CPU is overclocked?
Regardless, the one suspicious item you mentioned is the Rosewill PSU.
Can you borrow / beg / buy a higher wattage & higher quality PSU to try?
With all of the stuff in your machine, I'm surprised that PSU even works at all.
