- Jan 5, 2003
- 22
- 0
- 0
Hello all the experts,
I just put togetther a system using Shuttle AK31 board and AMD 700 MHZ CPU.Everything is fine, the system booted up but when I tried to load the Window 98 SE, everyting is going fine until the COPYING FILES part,the system froze up when 7% of the files is copied.I tried several times and the most I could get is 13%of the files and it froze up.I also tried to load Window XP professional and the same thing happened.I was able to run Window XP professional set up until the COPYING FILES and when I get 11% of the files copied,I lost video on my monitor and the system locked up.I can shut off the computer by holding the power button in for about 30 seconds. I wonder what is going on? I never had this problem before.I've built about 15 systems for friends and I've had many other problems but not this one.Any idea? I am sure some veteran builder out there knows the answer.
