Overclocking the Shuttle AK31 3.1 KT266a
Ok, here?s the deal. I picked up one of these to play with. Here?s what I?m using, at the moment:
Shuttle AK31 3.1 motherboard
Antec 412x 400 watt power supply
1.4 266fsb Tbird
Millennium Glaciator HS using AS paste
Visiontek Geforce 3
IBM 10/100 lan card
2 ? 256 meg Crucial PC2100 memory*
20 gig Maxtor 7200 ata66 HD
Cheapo 50X CD rom
NO SOUNDCARD(at the moment)
*started system with 1 - 256 meg Crucial PC2100 memory at first, in first mem slot
Booted system up, entered BIOS and set the following:
Disabled sound, serial & parallel ports, audio, joystick, & midi
Set USB to use ports 1 only
Disabled Video Bios Shadow
Installed Window 98(not SE), updated on net w/ IE 5.5 & Direct X8.0a
Installed 4.34 4 in 1?s
Installed nVidia 21.83 drivers
Installed GeForce tweeker , set to performance & O/C to 215/520
Entered BIOS & disabled USB, and set the following:
Memory to 2.7 volts, CAS 2, 4 interleave, Trp - 2T, Tras - 5T, Trcd - 2T, Queue Depth 4 & Command Rate at 1T
Set the Processor to 10X160, +.75 volts & booted system. Would post, loaded windows, but no go on Sisoft. Through trial & error, established that I could run stable at 158 fsb. Here are stats:
CPU ? 4437/2177
Multimedia ? 8649/10789
Memory ? 914/1147(WOOT!!!)
3Dmark 2000 ? 10,597
3Dmark 2001 ? 7,298
Installed second 256 meg Crucial PC2100 memory in slot 2 and ?? WTF, nada!!!! System would post, but that?s all! Trouble!!! Understand that I have a total of 6 - 256 meg Crucial PC2100 memory, and tried them all, through trial & error, could get into windows at 10.5 X 145, but 3Dmark would not run. OK, time to rethink this whole thing. Went back & ran benchmarks on each memory stick & found that I had only 2 that would do 158 fsb -?hey what did u expect? Installed both in slot 1 & 2 and?..same problem! Again, through trial & error got the system working with memory in slots 1 & 4(!!!!!) at 10 X 155, stable! Here are stats:
CPU ? 4364/2147
Multimedia ? 8511/10660
Memory ? 893/1109(STILL WOOT!)
3Dmark 2000 ? 10,771
3Dmark 2001 ? 7,251
Next up is install of Soundblaster Audigy soundcard?..stay tuned!
Also posted at Amdmb & OCworkbench
1.4 266fsb Tbird
Visiontek Geforce 3
IBM 10/100 lan card
Cheapo 50X CD rom
CPU ? 4437/2177
3Dmark 2001 ? 7,298
CPU ? 4364/2147
3Dmark 2001 ? 7,251
