Shuttle AK3.1 L11 and L1 Need More Juice
Clocker
1,353
Hey
I closed my L1 bridges and the chip was unlocked. Then I proceeded to close the L11 bridges to make the chip run at 1.85 volts default. However, I want more juice and even though my motherboard allows me to increase the voltage it doesnt work.
Which mod can I perform the would be the most parsimonious.
Clocker
WA261
4,631
you have to do a vmod on it....go to amdmb.com and check out the shuttle section there....w/out the mod 1.8 is all you can get...i did it and can run at 2+..i only needed 1.9 to get stable at 1600.
